need newer ptc_d for WF1 M230 linux
ptc-117681
I have a seat of Wildfire 1 M230 for linux that quit working when I upgraded glibc to version 2.5. I have traced the problem to the ptc_d vendor deamon executable. Could someone send or make available a copy of that file from a newer instalation? (it is at path_to_license_server_install/i486_linux/obj/ptc_d) Thanks! poulsone at a s m e dot org
2 REPLIES 2
hi
if you manage to get a ptc_d for linux
please send me a copy - -
Seems like that would violate the license. So, Pro/E might not accept the license if you used a WF2 vendor deamon with a WF1 license. You should probably think about going back to the previous version of glibc. If you are going to use old software you need to leave your computer in a state that the software needs it to be in. If you need a computer to do newer stuff, maybe you need to get a second computer.
Sorry. I would be scared to send anything. I don't want PTC to have to search me out for violating the agreement.
