How can change the default 3d orientation to 2d orientation while creating sketch using creo parametric 2.0. Is it is possiable.
R.Arunnethaji,
Techchnical support
Mindpower Engg solution, Chennai
file> option>sketcher> start up make the plane normal to screen check the box.
Hi Jayanta Sarkar,
Thanks for the response for my query. It is very useful for me.
Thank You,
R.Arunnethaji,
