We recently upgraded our server and are having issues with play path not working for holemaking cycles when working on network drives. After some time pro/e returns an error: cannot open file "cycle.ncl" check write permissions. Of course the write permissions seem correct, user has "full access". This error does not come up when working off a local drive. If you give pro/e 20 minutes its does seem to eventually work.
Wildfire 4.0 m030, running windows server 2003 r2
