regedits for a bunch of machines?
  • May 8, 2007
  • 578 views
Seems like every time I turn around there's another change to make to the
registry for Windchill.
I'm looking for a way to add specific changes to the registry on a bunch of
client machines without blowing away the existing registry. Any ideas?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
    David-
    Try exporting the registry key from a machine that has the key you
    want and saving it as a .reg file. This can be done by using the "export"
    command from the registry editor. (regedit) Once this is done, you can just
    have the users double click on the .reg file you exported, and the key
    should be added to their registry. This will keep the rest of the registry
    intact, and only change the key you have specified.
    Rob Presley
    Senior Consultant
