section thicken ??
  • September 25, 2008
  • 11 replies
  • 3701 views
It probably is right in front of my face, but I don't see it
Where did section thicken go ?
I'm on wildfire 3.0 M110
    Hi Liek,
    See the attached picture.
    Regards
    Jeff
    llam1-VisitorAuthor
    I received two replies pointing me to
    Edit Thicken and the option on the dashboard during thin feature
    creation.
    What I'm looking for is shown in attached picture.
    There used to be an option right inside the sketcher where you could
    offset the sketch (thicken)
    This would then result in an offset dashed line that could be used as
    dimension reference
    Liam,
    The image you sent is similar to the sheet metal sketch in a flange feature
    creation. This MCAD post
    Like,
    Attached is an example of using sketch thicken (in sketch mode) when
    creating a sheet metal flange. I tried to thicken a stand-alone sketch, but
    this option was not available.
    I found it in the 'Feature Tools' section of the Sketch menu while
    creating a flange wall in sheet metal. However, 'Feature Tools' is
    grayed out during creation of a solid thin.
    This is WF2, maybe WF3 or WF4 is different.
    Doug Schaefer
    September 25, 2008
    Lam,
    Thicken option is available only in Sheetmetal mode. Seems that you are working in part mode.
    -Parag Pendharkar
    Liek,
    I think this is what you are looking for. SKETCH -> FEATURE TOOL ->
    THICKEN
    Calvin
    Liek,
    In Wildfire, this option was removed from thin features in solid models,
    and is only available in sheetmetal mode now. Not sure if this was
    intentional or an oversight, but either way was a bad move with no good
    reason behind it as far as I can tell.
    Best Regards,
    All,
    The option was removed from the sketcher interface.
    You can still thicken a line entity though in the solid extrude. It is not just available in Sheetmetal.
    The "thicken" function is in the dashboard.
    Sketch a thin entity in the sketcher, accept it, then the toggle for the thicken is to the right of the "remove material" toggle. It looks like a "C".
    When you toggle the thicken, another width pane becomes available.
    Hope this helps.
    >>> "Eric Hill" <-> 9/25/2008 9:49 AM >>>
    Liek,
    Best Regards,
    Scott,
    The sketcher functionality is different than the actual thin feature.
    In the past, when creating a thin feature, you could show the other side
    of the thin in the sketch.  Those dashed entities could then be used for
    constraints and dimensions, allowing you to use both side of the thin to
    capture your design intent within the sketch.  Very handy, but now gone.
    Doug Schaefer
