Community Tip - You can subscribe to a forum, label or individual post and receive email notifications when someone posts a new topic or reply. Learn more!
X
Has anyone been able to successfully apply TPI 31383 which says if you create relations: default_xhatch_spacing=.09 default_xhatch_angle=45 then all new cross sections will have this as the default values? I am using Wildfire 2 and it doesn't seem to be doing anything...
I've got the same problem in proe 2001 2005030, in proe wf2 m171 and also in proe wf2 m250. the angle option works and the spacing option doesn't... I'm afraid that this is a mistake in the program language. Is there any other experience or solution for this issue?
