zig-zag broken view
joe.caulfield
zig-zag broken view
I've made a broken view correctly, but it is broken with straight lines to do not protrude beyond the object lines. Typically, a broken view has two zig-zag lines that protrude beyond the object lines, but I don't see how to set those as an option..... Joe
Double click on the view & under Visible Area where you have given the Broken View option & selected the 1st & 2nd break line...... scroll to the right of the option & you will find different options for Break line style, including sketch wherein you can even sketch the style you want.....
