Accessing assembly parameter using Toolkit or J-link
Participant
Has anyone used Toolkit or J-link to pull the tube length from a Pro|Piping
assembly?
I posted the message below to the "Pro-user" list a few weeks ago with very
limited response. I contacted PTC about the issue and was told that it
could not be done. I wonder if there is another approach I can try. I have
no experience doing this sort of thing, but if it is possible I would be
willing to look into it.
Original Post is below:
I would like to access the Pro|PIPING pipeline parameter
&asm.mbr.pipe.line.len.pre_cut for use in a relation. I'm trying to write a
relation that will create a string parameter that is a combination of our
tube description parameter and the tube length. I think I can do this using
the itos() function to convert the length to a string value. I can't seem
to figure out the required syntax to access the length value. Any ideas?
Mike Phillips
The Trane Company
