Add menu to Pro/E menu bar in WF4 64bit
ptc-161645
I am compiling our utilities for WF 4 for 64 bit, and I can not get one
of my toolkit dll files to load into Pro/E. The file is very simple, it
just adds a menu to the Pro/E menu bar and adds a few sub menus. When
it loads, it gives a PRO_TK_GENERAL_ERROR. I have tried everything I
can think of, including the sample code from the Pro/TK user guide and
the pt_examples included in the Pro/Toolkit install directory, and they
all give the same PRO_TK_GENERAL_ERROR error. The pt_install_test, and
one of my utilities that adds a button to an existing menu, both work
ok. Anyone have any idea on what the problem may be, or on how to debug
this?
Scott Edsell
TYCO Electronics
Did you compile the application with the 64 bit target or the 32 bit
target?
Patrick Williams | Sr. Application Engineer | Engineering Systems |
Steelcase Inc. | 616.698.4078 | My Site
<">http://my.steelcase.com/Person.aspx?accountname=NA\PWILLIA3>
Patrick,
I use makefiles which are based on the sample make files.
MAKEFILENAME = makefile64
# Machine Type
PRO_MACHINE_TYPE = x86e_win64
# Executable names
EXE = TYCOmenu64.exe
EXE_DLL = TYCOmenu64.dll
# Pro/Toolkit Source & Machine Loadpoint (EXTERNAL USE - DEFAULT)
PROTOOL_SRC = C:/EngApps/PTCpro/wf4_m030_x64/protoolkit/
PROTOOL_SYS = $(PROTOOL_SRC)/$(PRO_MACHINE_TYPE)
PRODEV_SRC = C:/EngApps/PTCpro/wf4_m030_x64/prodevelop
PRODEV_SYS = $(PRODEV_SRC)/$(PRO_MACHINE_TYPE)
INCS = -I. -I$(PROTOOL_SRC)/includes \
-I$(PRODEV_SRC)/prodev_appls/includes -I$(PRODEV_SRC)/includes
# Compiler Flags
CC = cl
MACH = -DPRO_MACHINE=36 -DPRO_OS=4
CCFLAGS = -c -GS -fp:precise -D_WSTDIO_DEFINED -DAMP_PC -DREGEX_MALLOC
CFLAGS = $(CCFLAGS) $(INCS) $(MACH)
# Libraries
PTCLIBS = $(PRODEV_SYS)/obj/prodevelop.lib
$(PROTOOL_SYS)/obj/protoolkit.lib
PTCLIBS_DLL = $(PRODEV_SYS)/obj/prodev_dll.lib
$(PROTOOL_SYS)/obj/protk_dll.lib
LIBS = libcmt.lib kernel32.lib user32.lib wsock32.lib ole32.lib
advapi32.lib mpr.lib winspool.lib netapi32.lib psapi.lib gdi32.lib
shell32.lib comdlg32.lib
OBJS = TYCOmenu.obj
# Linker
LINK = link
$(EXE) : $(OBJS) $(PTCLIBS)
@echo Start at `date`
@echo PROTOOL_SRC = $(PROTOOL_SRC)
@echo PROTOOL_SYS = $(PROTOOL_SYS)
#Executable applications compiled using WinMain() instead of main()
should set the subsystem to windows instead of console.
$(LINK) /subsystem:console -out:$(EXE) /debug:none @<<longline.list<br/>
$(OBJS) $(PTCLIBS) $(LIBS)
@echo Finished at `date`
del $(OBJS)
# Dll target
dll: $(EXE_DLL)
$(EXE_DLL) : $(OBJS) $(PTCLIBS_DLL)
$(LINK) /subsystem:console -out:$(EXE_DLL) /debug:none /dll
$(OBJS) $(PTCLIBS_DLL) $(LIBS)
# object dependencies
PROTK_APPLS = $(PROTOOL_SRC)/protk_appls/pt_af_examples
PROTK_UTILS = $(PROTOOL_SRC)/protk_appls/pt_examples/pt_utils
TYCOmenu.obj: TYCOmenu.c
$(CC) $(CFLAGS) TYCOmenu.c
clean :
del $(OBJS)
del $(EXE)
nmake -f $(MAKEFILENAME)
clean_dll :
del $(OBJS)
del $(EXE_DLL)
nmake -f $(MAKEFILENAME) dll
The problem was that I had installed VS 2005 SP 1 on the 64 bit system.
This is not supported, so I uninstalled and reinstalled VS 2005 and
recompiled the DLLs, and now everything is working. Thank you for all
of the replies.
Scott
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
