Cannot run program - error code
ptc-2882305
After I instal the program (Cocreate PE) I try to run it but I get this message: This application has failed to start because AVIFIL32.dll can not be found.... So I re-installed and repaired several times with no success getting the same error every time.
Hi, We never saw that before. I found that link which could perhaps help with that issue: http://pcsupport.about.com/od/findbyerrormessage/a/avifil32-dll-not-found-missing-error.htm Hans-Georg
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
