Coping Parameter values from Part to Drawing
ptlw1778
Does anyone out there know of a way or a Toolkit function that can read a Part or Assembly parameter while in a Drawing parameter. I have code that reads that reads a parameter from within the drawing that I can then copy to another parameter, I just have not been able to figure out how to access a the part parameters while in the drawing.
Thank you,
Tom
Tom,
You need to get the part handle for the part on the drawing. With that,
you'll be able to access the part/assembly parameters.
Bob
Robert A. Monat
Jerand Technical Services, Inc.
http://www.jerand.com
Phone: 317-875-6087 FAX: 317-875-6612 Tollfree(US)888-4JERAND
tom.willis@oregonchain.com wrote:
>Hello,
>Thank you,
>Tom
>You are currently subscribed to toolkits.
>To unsubscribe send a blank e-mail to -.
>For assistance, email us at - or find other contacts at www.ptcuser.org/org/contacts.html.
>PTC/USER and the PTC/USER logo are registered trademarks of PTC/USER, Inc.
>Pro/ENGINEER is a registered trademark of PTC.
>Message authors are solely responsible for the content of their posts.
Tom,
Here is how I get to Part parameters from a drawing...
ProMdlCurrentGet (&drawing);
ProDrawingSolidsCollect (drawing, &solids);
/* If there is only 1 solid associated with the drawing */
model = solids[0];
/* if more than 1 solid, then you need to determine which one you want
to use */
ProMdlToModelitem(model, &modelitem);
ProStringToWstring(tmp1, "Title"); /* A parameter called "Title" */
ProParameterInit(&modelitem, tmp1, ¶m);
ProParameterValueGet(¶m, &part_title);
ProWstringToString(title, part_title.value.s_val);
ProStringToWstring(tmp2, "Rev"); /* A parameter called "Rev" */
ProParameterInit(&modelitem, tmp2, ¶m);
ProParameterValueGet(¶m, &part_rev);
ProParamvalueTypeGet(&part_rev, ¶m_type);
if (param_type == PRO_PARAM_STRING)
ProWstringToString(*rev, part_rev.value.s_val);
else if (param_type == PRO_PARAM_INTEGER)
fprintf("ERROR: Rev param is an integer!\n");
return(PRO_TK_GENERAL_ERROR);
John
>Hello,
>Thank you,
>Tom
Inc.
Inc.
Here's another piece of code for that purpose, used to copy/create
parameters from model to drawing.
// Use the current drawing.
status = ProMdlCurrentGet ((ProMdl*)&drawing);
if (status != PRO_TK_NO_ERROR)
return (status);
// Get the drawings current/active model.
status = ProDrawingCurrentsolidGet ((ProMdl)drawing, &solid);
return (status);
// Set parameter type and value.
for(i=0; i<7; i++)
if(i == 0) ProStringToWstring(name, "DESCRIPTION");
if(i == 1) ProStringToWstring(name, "NUMBER");
if(i == 2) ProStringToWstring(name, "RESPONSIBLE_DEPARTMENT");
if(i == 3) ProStringToWstring(name, "TAKE_OVER_DEPARTMENT");
if(i == 4) ProStringToWstring(name, "PRODUCTTYPE");
if(i == 5) ProStringToWstring(name, "PROJECTID");
if(i == 6) ProStringToWstring(name, "REVISIONTEXT");
value.type = PRO_PARAM_STRING;
// Make model current obj
status = ProMdlToModelitem (solid, &modelitem);
status = ProParameterInit(&modelitem, name, ¶m);
// If the parameter doesn't exist in the model, create it in the model
// with empty string. Otherwise get its current value.
if (status == PRO_TK_E_NOT_FOUND)
ProStringToWstring(value.value.s_val, ");
status = ProParameterCreate (&modelitem, name, &value, ¶m);
else
status = ProParameterValueGet(¶m, &value);
ProWstringToString(astr, value.value.s_val);
// Make drawing current obj
status = ProMdlToModelitem ((ProMdl)drawing, &modelitem);
// If the parameter doesn't exist in drw, create it with empty string.
// Otherwise set it's value to the same as from the model.
ProStringToWstring(value.value.s_val, astr);
else
status = ProParameterValueSet(¶m, &value);
Tommy
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
