Extracting point data from ProE into Excel.
jhengel
Does anyone know how I can extract point data from ProE into an Excel
spreadsheet?
John Hengel
MCAD Applications Support
National Ignition Facility
Lawrence Livermore National Lab.
(925) 422-7608
6 REPLIES 6
bfrandsen
6-Contributor
(To:jhengel)
John, it can be done using one of the available APIs (Pro/TOOLKIT, J-LINK,
Web-Link and VBS from WF4).
So the choice will be based on wether you are a C, Java JavaScript or
Visual Basic programmer.
All API's are documented in the APIWizards found subfolders names after
the API in your installations Pro/ENGINEER directory.
If you will be using J-Link like me, you could either write a .csv file
using Java's IO capabilities or use the Open Source HSSF API for writing
direct to Excel.
I believe VBS could give you the most direct solution, but it will require
WF4.
Bjarne
"John Hengel" <->
09-04-2008 16:08
Please respond to
"John Hengel" <->
To
cc
Subject
[proecus] - Extracting point data from ProE into Excel.
spreadsheet?
John Hengel
(925) 422-7608
-----End Original Message-----
gbon
(To:jhengel)
I suppose you want points data from a Proe part.
So you can export a binary stl file and the open it with excel.
You will have something like :
facet normal 2.855993e-15 -8.762533e-01 -4.818508e-01
outer loop
vertex -2.561429e+02 1.657247e+01 -4.834429e+02
vertex -2.519444e+02 -2.354579e+00 -4.490237e+02
vertex -2.527500e+02 -3.291503e+00 -4.473199e+02
endloop
endfacet
facet normal 9.238522e-01 -1.844281e-01 3.353854e-01
outer loop
vertex -2.527500e+02 2.135097e-01 -4.453925e+02
endloop
endfacet
facet normal -1.494843e-14 -8.762533e-01 -4.818508e-01
so you can sort lines for keeping all vertex (points) lines.
Then you can converts thoses lines to have 4 columns :
first column always contain "vertex" and you can delete it
then you will have x, y and z columns.
GB
FV
(To:jhengel)
Hi all,
John,
A poor man solution(no programming required)would be manuallypick surfacelocations or datum points with Analysis->Geometry->Point Pro/E menu selection and extract measurments from a trail file with grep or findstr depending on OS.
HIH.
Feliks.
In Reply to:
spreadsheet?
John Hengel
(925) 422-7608
In Reply to:
spreadsheet?
Can you be a little more specific? What do you mean by "point data"?
Are you looking for XYZ position data for datum points?
Marc
Marc Mettes
Visit My CAD/PDM AutomationBlog
In Reply to:
In Reply to:
spreadsheet?
You can extract point data (i.e XYZ position data) and send it to
Excel using Pro/WebLink, no external programs or files required,
unless you want that. I can post an example if you're interested.
Marc
Marc Mettes
Or, Subscribe to My CAD/PDM Automation Blog by Email
In Reply to:
Does anyone know how I can extract point data from ProE into an Excel spreadsheet?
I have posted an example of sending Pro/ENGINEER point data to Excel using Pro/WebLink on my blog:
http://inversionconsulting.blogspot.com/2008/04/weblink-send-proe-pnt-data-to-excel.html
If it's not what you're looking for, it might be of interest to others.
Marc
Marc Mettes
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
