Hello All,
I am trying to create dimensions in section using Pro/Toolkit. I am not able
to create dimensions at locations specified by Pro2dPnt point.
I tested a simple code of creating a horizontal and one vertical line and
dimensioning them. Dimensions are getting created on the lines itself.
Note: When I tried creating a single line and dimensioning it, dimension is
getting created correctly.
Any help or hint here is appreciated. Thanks in advance.
Following is the relevant part of the code:
