Hidden features
berry
Hidden features
Hi everybody,
as far as you know, is it possible to determine via toolkit (proe wf
2.0) whether a subcomponent is hidden in the model tree? I mean a
component on which the user did the "Hide" operation from the context menu.
I've tried two functions, ProFeatureVisibilityGet() and
ProAsmcomppathVisibilityGet(), but their purposes are different...
Thank you very much
-Stefano Berretta
sergio72
(To:berry)
May be using "ProFeatureStatusGet()"??? that function retrieve the
following feature status codes for tk2001 maybe in wf2.0 will be more codes
PRO_FEAT_INVALID: /* input was invalid */
PRO_FEAT_ACTIVE: /* feature is active */
PRO_FEAT_INACTIVE: /* feature is inactive */
PRO_FEAT_FAMTAB_SUPPRESSED: /* feature is suppressed by family
PRO_FEAT_SIMP_REP_SUPPRESSED: /* feature is suppressed by
PRO_FEAT_PROG_SUPPRESSED: /* feature is suppressed by
PRO_FEAT_SUPPRESSED: /* feature is suppressed */
PRO_FEAT_UNREGENERATED: /* feature is active but
let me know if you find a solution for it
"Stefano
Berretta"
<stefano_berretta to=" <br="/> @virgilio.it> lista-toolkit
23/08/2007 11:31 cc
Subject
Please respond to [proecus] - Hidden features
"Stefano
Berretta"
<stefano_berretta <br="/> @virgilio.it>
Hi everybody,
Thank you very much
-Stefano Berretta
bokir
(To:berry)
> Hi everybody,
> Thank you very much
> -Stefano Berretta
When the user hides an item in Pro/ENGINEER, it is actually placed on
a special layer called ".BLACK_HOLE". This layer is not visible in
Pro/ENGINEER interface, but in earlier builds of Pro/ENGINEER it was
possible to access this layer programmatically. PTC has disabled
access to the layer in one of WF2 builds. Before, while it was still
possible to access the layer, you could use
ProLayerItemsGet() on the black hole layer to check if an item is
there. It was also possible, by placing and removing the item from
this layer, to emulate the funcionality of Hide and Show interface
commands.
Currently, I am not aware of any way to check if an item is hidden or
to show/hide it.
Bojan Resnik
Hi Stefano,
In WF 2.0 build M260 they added new Hide/Unhide functionality.
Specifically they added:
ProModelitemIsHidden
ProModelitemHide
ProModelitemUnhide
There is a TAN 136836 describing them in more detail.
Here's a link:
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
