How to Select Drawing View non-interactively....
bharatp
Hi folks,
Has anyone been able to select a drawing view non-interactively using toolkit...i need to set/modify the cross section properties of the projected views after creation ....
bharat
Bharat,
Look up the function ProDrawingViewsCollect. Or ProDrawingViewsVisit. You
can determine what sheet the view is on and what solid is contained in the
view. Hope this helps.
Patrick Williams
Application Engineer
Steelcase, Inc.
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
