Hi All,
In Pro/TOOLKIT User's Guide, there are many APIs relating to Mechanica Items and Geometry. However, for Mechanism, Pro/TOOLKIT users can only create Spring and Damper features. Does anyone has idea to get Mechanism items via Pro/TOOLKIT? For example, the bodys, the connections, the motors, the forces and torques, and the analyses.
Any ides is appreciated.
Hivan
Hi Patrick,
As your suggestion, I read section "The Element Tree for an Assembly Component" in chapter "Assembly: Assembling Components". From the element tree of an assembly component, we can get the most mechanism connections: fixed, pin, slider, cylindrical, planar, ball, weld, bearing, general, 6DOF, slot, and user defined type. And also the friction for the motion axis.
However, other mechanism conncetions only appear in Mechanism mode (cam-follower, gear) do not in this element tree. And there is no information for other mechanism items: motors, force, torque, and so on. I need more investigation for these mechanism items.
Anyway, thanks for your kindly help. If I can find any helpful, I will share it here.
Hivan
