How to extract Mechanism Items via Pro/TOOLKIT
greatprairie
Hi All,
In Pro/TOOLKIT User's Guide, there are many APIs relating to Mechanica Items and Geometry. However, for Mechanism, Pro/TOOLKIT users can only create Spring and Damper features. Does anyone has idea to get Mechanism items via Pro/TOOLKIT? For example, the bodys, the connections, the motors, the forces and torques, and the analyses.
Any ides is appreciated.
Hivan
Hivan,
I have not ever interrogated mechanism constraints of an assembly model but here is what I would try first. I do not see any specific Mechanism API's. Therefore; I would extract the feature element tree for the assembly component. Within the tree you can acquire the mechanism data (connections, movement, friction, etc.). Read the API Wizard under User's Guide->Assembling Components->The Element Tree for an Assembly Component. This section is the complete explanation of the assembly component feature tree. Hope this helps.
Patrick Williams | Engineering Systems | Sr. Applications Engineer | Steelcase Inc. | 616.698.4078
[cid:image003.jpg@01CA1B28.5411B990]
Hi Patrick,
As your suggestion, I read section "The Element Tree for an Assembly Component" in chapter "Assembly: Assembling Components". From the element tree of an assembly component, we can get the most mechanism connections: fixed, pin, slider, cylindrical, planar, ball, weld, bearing, general, 6DOF, slot, and user defined type. And also the friction for the motion axis.
However, other mechanism conncetions only appear in Mechanism mode (cam-follower, gear) do not in this element tree. And there is no information for other mechanism items: motors, force, torque, and so on. I need more investigation for these mechanism items.
Anyway, thanks for your kindly help. If I can find any helpful, I will share it here.
Hivan
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
