I am trying to get ProE Wildfire 3.0 to show the J-Link program or to even run the install test and I have been unable to get ProE to show any indication that J-Link was installed other than the J-link folder in the install directory. Is there a manual (other than the J-link manual) that helps explain how to get ProE to work with J-Link? I am fairly new to programming and didn't expect it to be so "user friendly" (I hope you caught the sarcasm) right out of the box. I have managed to learn multiple programming languages yet the method for getting the add-on to function with ProE is killing me and I would really appreciate some direction as to what I am missing between installing ProE and getting it going. Thanks for your help. Other information: -I do not have Pro Toolkit -I do have a Java compiler -I do have a Java IDE
