JLink question: importing relations
lylebeidler
I'm having trouble importing relations into my model.
Here's what I have:
String relationsFileName =
"z:/engineering/IL_START/configurator_relations.txt";
File relationsFile = new
File(relationsFileName);
if (relationsFile.exists())
try {
RelationImportInstructions importInst =
pfcModel.RelationImportInstructions_Create();
model.Import(relationsFileName,importInst);
}// end try
block
catch (Exception e)
{writeLog("Error
importing relations" + e);
mesg = "error
importing relations";
}// end if relationsfile
exists
else
{mesg = "relation file not
found";
The underlined line is what I'm having trouble with. I know for the Import
command to work, I need ImportInstructions, but for the life of my I can't
figure out what that is supposed to accomplish.
Can any of you gurus help me with this?
Thanks!
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
> ... I know for the Import
> figure out what that is supposed to accomplish. ...
For relations, the instructions are simply a placeholder object in the
Import() and Export() methods. The steps you are following look correct,
if you're using WF3. In WF4, there is a more direct way to access relations.
What type of problem are you having exactly?
Marc
Marc Mettes
Visit My CAD/PDM AutomationBlog
Or, Subscribe to My CAD/PDM Automation Blog by Email
Turns out the answer is: I'm an idiot.
The relations I was importing in referenced parameters I had not yet added
into the model, so the Relations dialog was throwing a "Relations have an
error" message, which my error checking was not showing me.
Lyle Beidler
MGS Inc
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
