Need Help in Drawing Polygon using 3D Point
Ravindra
We are working on displaying some userdefined entities in Graphics windows.
We want to display the filled Polygon in 3D view.
In the existing document there is an API "ProGraphicsPolygonDraw"
which takes 2dPoint as an input; hence the polygon can be drawn only on x-y plane.
We are finding how we can draw filled polygon which uses 3dPoint as input and creates 3D view of filled polygon.
Does anyone have any inputs on this?
Have anyone displayed the user defined entities in Graphics view of ProE using ProToolKit?
Any pointers to the approach are appreciated.
Thanks in advance.
Ravindra.
Rivandra,
You must use 3D display lists. Read the API Wizard under User's
Guide->Graphics and Object Display->Display Lists. This will get you
started.
Patrick Williams
Application Engineer
Steelcase Inc.
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
