I am a mechanical engineer that likes to program on occassion. Ihave used mapkeys, trailfiles and UI scripting to solve various repetitive tasks in Pro/E and Intralink.Now I would like to begin using J-Link programming tohandle some repetitivePro/E tasks that aren't well suited to mapkeysor trailfiles. I was able to get thesource files for the InstallTest sample applicationto compile and the auxilary application starts when I open Pro/E however I do not see any new menu selections in the File menu as advertised in the User Guide. Can anyone provide any pointers on potential problems? Thanks in advance.
I am currently looking to use J-Link to do the following as my first projects:
1) Add a new menu selection for a mark-up note that automatically
places the noteon a special layer and uses a special text formatting.
2)Add a menu selection allowing a user to update existing drawing tables.
We have a new format the replaces the EC history notes with parameters.
I want to grab the contents of the table on the first sheet and write the info.
to parameters, then replace the the format with the latest version on all sheets.
Mark Bohannon
IBM
