Populating a Dashboard's Standard Layout
mark_stallard
Hi Everyone -
I'm trying to add OK (checkmark) and Cancel (X) pushbuttons to
the standard layout of a dashboard, but I'm finding it difficult
for want of a good example. In the Wildfire 3 Pro/Toolkit docs,
there are apparently no dashboard programming examples at all.
Here's a summary of the process I'm using:
1. Use ProUIDashboardpageoptionsAlloc() and
ProUIDashboardshowoptionsAlloc() to set up the main
dashboard page.
2. Use ProUIDashboardshowoptionsNotificationSet() to set
a callback for the dashboard's events
3. Call ProUIDashboardShow(), which triggers the events
PRO_UI_DASHBOARD_CREATE and PRO_UI_DASHBOARD_SHOW.
4. Upon trapping PRO_UI_DASHBOARD_CREATE, use
ProUIDashboardStdlayoutGet() to get the dashboard's
standard layout name. The trapped name is typically
"dashInst0.stdbtn_lay".
5. Here's where I get stuck: Add the new buttons, which
are already defined a .res file containing with a
"Layout ( ... )" defintion, using ProUIDialogLayoutAdd()
or ProUILayoutLayoutAdd(). I usually get the return
value PRO_TK_GENERAL_ERROR.
I have tried all kinds of shenanigans with the dialog name and
layout name arguments for ProUIDialogLayoutAdd() and
ProUILayoutLayoutAdd():
A. Using "dashInst0.stdbtn_lay" as the dialog name.
B. Using the dashboard resource file name as the dialog
name and "dashInst0.stdbtn_lay" as the layout name.
C. Splitting the standard layout name on the "." to use
"dashInst0" as the dialog name and "stdbtn_lay" as
the layout name.
D. Using an empty string or NULL as the dialog name.
Using NULL causes ProUILayoutLayoutAdd() to return
PRO_TK_BAD_INPUTS.
None of this has worked so far. Has anyone had better luck
putting buttons in the standard layout of a dashboard?
I'm running Pro/Engineer Wildfire 3 Build M080 on Windows XP.
Thanks!
|+| M a r k |+|
- Mark Stallard
- Raytheon Company
- Sudbury, Massachusetts USA
I owe two "thank you's" to Scott Connover at PTC. Scott sent
me a reply to my earlier message, but I had already searched
the proecus archives and found some helpful advice that he
gave on this subject back in February.
While I still can't load a sublayout from a .res file into a
dashboard's standard layout area, I was able to add pushbuttons
using ProUILayoutPushbuttonAdd(). The important step I was
missing was to use the dashboard main page device name from
ProUIDashboardpageDevicenameGet() as the dialog name in
Thanks again, Scott!
|+| M a r k |+|
"Mark R Stallard" <->
07/25/2007 12:16 PM
Please respond to
To
cc
Subject
[proecus] - Populating a Dashboard's Standard Layout
Hi Everyone -
dashboard page.
the layout name.
PRO_TK_BAD_INPUTS.
Thanks!
|+| M a r k |+|
- Mark Stallard
- Raytheon Company
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
