Printing in J-Link/VB API - Update
ptc-2245085
I was unable to get the API calls to work to print drawings from VB. I
also had problems getting Pro/E to print from a macro with no_graphics
mode turned on.
The solution I finally came up with is to use Pro/E to print to a .plt
file and then run the plotter command (as found in the .pcf file)
directly on the .plt created by Pro/E. It may not be elegant, but it
works with everything I've thrown at it.
The algorithm looks something like:
For each drawing to be printed
____Switch Pro/E's working directory to the directory of the drawing
____Open the drawing
____Run a macro to print the drawing to a .plt file
____Close the active Pro/E window
____Clear all undisplayed models from memory
____Call the plotter command in the appropriate .pcf file to print the
.plt file
____Delete the .plt file
The macro I'm using (on Wildfire 4) is:
~ Activate `main_dlg_cur` `Windows.psh_win_activate`;
~ Command `ProCmdModelPrint`;
~ Activate `print` `print`;
! This is for printers on the initial drop-down list
~ Activate `print` `__PUT THE PRINTER NAME HERE__`;
~ Activate `print` `ToFile` 1;
~ Activate `print` `ToPrinter` 0;
~ Activate `print` `OK`;
~ Update `Print_file` `Filename` `__ENTER THE .PLT FILE PATH HERE (be
sure to escape backslashes)__`;
~ Activate `Print_file` `OK`;
or
! This is for printers on the more printers list
~ Activate `print` `MorePrinter`;
~ Select `generic_list` `Selections` 1 `__PUT THE PRINTER NAME HERE__`;
~ Activate `generic_list` `OK`;
The way you know where a printer will be is that Pro/E lists the first 9
printers alphabetically on the initial drop-down list and then puts the
rest in the more printers list.
For VB.NET, I would use the Process object to execute the plotter
command.
The code for that is:
Dim PlotterProcess as New Process
PlotterProcess.StartInfo.FileName = "cmd.exe"
PlotterProcess.StartInfo.Arguments = "/c " & PlotterCommand & " " &
PlotFilePath
PlotterProcess.StartInfo.WindowStyle = ProcessWindowStyle.Hidden
PlotterProcess.Start()
PlotterProcess.WaitForExit()
PlotterProcess.Close()
In Java, it can be more complicated. See:
0 REPLIES 0
