Re: how to connect wildfire2 through toolkit in asynchronous mode
MarcMettes
> From: "Madhava Rao" <madhava@idolafori.com>
> Below is the code which I have followed to connect to pro-e
> wildfire2 through asynchronous mode.
> I have set all the seeting in vc++ complier.
> I am able to generate the obj and exe file successfully.
> But while run the exe file the following error is occurring.
> Warning:4068 couldnot start message module 1073823185.
> Can any one tell me where I am going wrong in connecting to
> pro-e from externally.
In previous releases, the environment variable PRO_COMM_MSG_EXE
must be set to the pro_comm_msg executable (add .exe for win32)
before ProEngineerStart() and/or ProEngineerConnect(). Check
a working Pro/Engineer startup script (created by ptcsetup) for
an example.
Setting the environment variable can be done in a wrapper script,
batch file, or in the async app itself using putenv() or something
similar. I'm not aware of this being different for Wildfire 1 or
2.
If you are trying to ProEngineerConnect() to a session on another
machine, it seems to work only if you have the PTC portmapper
running, especially if you're connecting to a windows system.
Marc
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
