Re: .i need ur help
Highlighted
Re: .i need ur help
Hi easwaran
Hope you would have reveived the mail of Mr. Patrick Williams explaing the method of compling Pro/Toolkit applications. here the process has been explained in great details. This is one of the way
Another way which Pro/Engineer provides is using make_files.
I have attached a sample workspace along with this for your convinience
The following will explain what changes are required in make_files
My comments starts with #Abhishek and ends with #Abhishek
# File Name
MAKEFILENAME = make_Sample
#Abhishek
# If you change the name of the make file that is this file then replace "make_Sample" with the new file name
#Abhishek
# Machine Type
PRO_MACHINE_TYPE = i486_nt
# Executable names
EXE = Sample.exe
EXE_DLL = Sample.dll
#Abhishek
#To change the name of final exe or dll replace "Sample.exe" or Sample.dll" with the new file name with extension
#Abhishek
# Pro/Toolkit Source & Machine Loadpoint (EXTERNAL USE - DEFAULT)
PROTOOL = D:/ptc/proe2001
#Abhishek
#change the path to location where the ProE is installed on your machine
#Abhishek
PROTOOL_src=$(PROTOOL)/protoolkit
PROTOOL_SYS = $(PROTOOL_SRC)/$(PRO_MACHINE_TYPE)
PRODEV_src=$(PROTOOL)/prodevelop
PRODEV_SYS = $(PRODEV_SRC)/$(PRO_MACHINE_TYPE)
# Pro/Toolkit Source & Machine Loadpoint (PTC INTERNAL USE)
#PROTOOL_src=$(PTCSRC)/protoolkit
#PROTOOL_SYS = $(PTCSYS)
#PRODEV_src=$(PTCSRC)/prodevelop
#PRODEV_SYS = $(PTCSYS)
# Include File Paths
INCS = -I. -I$(PROTOOL_SRC)/protk_appls/includes -I$(PROTOOL_SRC)/includes \
-I$(PRODEV_SRC)/includes
# Compiler Flags
CC = cl
MACH = -DPRO_MACHINE=29 -DPRO_OS=4
CCFLAGS = -Dhypot=_hypot -DMSB_LEFT -Dfar=ptc_far -Dhuge=p_huge -Dnear=p_near -c -W2 -G4 -Za -D_X86_=1 -D_WSTDIO_DEFINED
CFLAGS = $(CCFLAGS) $(INCS) $(MACH)
# Libraries
PTCLIBS = $(PRODEV_SYS)/obj/prodevelop.lib $(PROTOOL_SYS)/obj/protoolkit.lib
PTCLIBS_DLL = $(PRODEV_SYS)/obj/prodev_dll.lib $(PROTOOL_SYS)/obj/protk_dll.lib
LIBS = libc.lib kernel32.lib user32.lib wsock32.lib advapi32.lib mpr.lib winspool.lib
# Object files
OBJS = Sample.obj pt_utils.obj
#Abhishek
# Replace Sample.obj and pt_utils.obj with the obj file actually created by you program. This will be decided from the below statements (*) . You can also add more .obj files
#Abhishek
# Linker
LINK = link
$(EXE) : $(OBJS) $(PTCLIBS)
@echo Start at `date`
@echo PROTOOL_src=$(PROTOOL_SRC)
@echo PROTOOL_SYS = $(PROTOOL_SYS)
#Executable applications compiled using WinMain() instead of main() should set the subsystem to windows instead of console.
$(LINK) /subsystem:console -out:$(EXE) /debug:none /debugtype:coff /machine:i386 @<<longline.list<br/>$(OBJS) $(PTCLIBS) $(LIBS)
@echo Finished at `date`
del $(OBJS)
# Dll target
dll: $(EXE_DLL)
$(EXE_DLL) : $(OBJS) $(PTCLIBS_DLL)
$(LINK) /subsystem:console -out:$(EXE_DLL) /debug:none /debugtype:coff /machine:i386 /dll @<<longline.list<br/>$(OBJS) $(PTCLIBS_DLL) $(LIBS)
del $(OBJS)
# object dependencies
PROTK_APPLS = $(PROTOOL_SRC)/protk_appls/pt_examples
PROTK_UTILS = $(PROTOOL_SRC)/protk_appls/pt_examples/pt_utils
Sample.obj: Sample.c
$(CC) $(CFLAGS) Sample.c
pt_utils.obj: $(PROTK_UTILS)/pt_utils.c
$(CC) $(CFLAGS) $(PROTK_UTILS)/pt_utils.c
#Abhishek
# (*) This is the section where the .c files are complied and converted into .obj files. make corresponding changes if you change the name of .c files. If you add new .c files then two line in above format for all the new files added
#Abhishek
clean :
del $(OBJS)
del $(EXE)
nmake -f $(MAKEFILENAME)
clean_dll :
del $(OBJS)
del $(EXE_DLL)
nmake -f $(MAKEFILENAME) dll
regards
Abhishek
easwaran chandrasekar <-> wrote:
hi abishek,
thks 4 ur msg. i have license for toolkit.and i have installed it also. . i
have also run toolkit test file.
i dontknow the way 2 modify the make file for my code.
pls help,
with regd,
easwaran
