SQLPlus commands
pwdmarshall
SQLPlus commands
Hi SQLPlus Gurus,
We're using Pro/I 3.3 M022, the server is Win2K.
I'm working with a Pro/Intralink Toolit app developed by someone else.
Quick question:
Can anyone tell me what sql commands I can use to find out the names of
attributes in Pro/Intralink?
More detail:
We have a Pro/E parameter Description, which seems to clash with the
Pro/Intralink default parameter Description. As a result, Pro/Intralink
seems to have created another attribute called Description* (see
screenshot).
If I use 'piv_desc' or 'description' the Pro/I Toolkit app returns the
values for the Intralink default description. If I use 'description*' the
search fails completely; so I want to use the name for 'description*' as
it's referred to in the Oracle table.
Thanks in advance,
Paul
For browsing your Intralink Oracle tables, I recommend a free tool
called "FreeTOAD"
Hello
I am no sql or intralink guru, but I have a little to add.
By the way, thanks for the toad link, I will use it once I get
back to work...ha..ha
My add is: I wrote a java gui to query oracle &/or Intralink.
http://www.datajett.com/Java/DbJettJT/
No, I'm not a java guru either. I just try to make all work.
It has a few drop-downs for sql to:
few oracle tuning/monitoring
intralink queries
It could be a good start. No commits, just queries, so it should
not be dangerous for a beginner (which I am still).
IN the above shown folder on my web site, you can use the jar,
complie the java & go form there.
You just enter/modify the URL string:
jdbc:oracle:thin:@Host_Name:1521:ilnk
with your host-name:port:SID.
All this info can be obtained from your tnsnames.ora (usually
located ion your .proi folder or near there).
Then enter user name & pass word (system/manager usually works).
Then select from drop downs:
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
