SUMMARY: Change default location of workspace.
dpilkey
Thanks to everyone for thier help.
ORIGINAL TEXT
How can I change my default location of workspace from C:\ptc\work\.proi to something of my choice. I prefer to place it on a backed up network server where it can be shared.
SOLUTION
Set your PDM_LDB_PATH environment variable to the path that you want.
A FEW NOTES
I placed the variable in C:\ptc\proiclient\bin\proilink.bat. It is a single line that looks like this:
set PDM_LDB_PATH=\\Ficus\CADFILES\PTC\WORKSPACE\
Of course you will have to put in your own path. "Ficus" is just the name of our server.
CONS
I received quite a few warnings about performance loss from other users. After running this for a month now we have not seen any problems. We are newbies so we're not exactly burning up the network.
I was also advised this may cause the workspace to become corrupt. We have not experienced that yet.
PROS
There is only 2 of us using this workspace. Under this setup both of us can work on any project as the situation dictates. We have even both worked in the same workspace at the same time. This would be much harder to do if the workspace was located on our individual workstations.
The server is backed up daily while our pc's are not.
Also be aware that PTC does not support this type of configuration...
To anyone who knows I have the following question as we were considering putting our .proi folders on a server at one time. If we follow the PTC suggestion to copy the local .proi folder to a common location each night for backup then if we did have a local problem would copying the .proi folder back onto the local drive have any problems with check-in of modified files into Ilink?
Dwayne Quatier
GE Healthcare
The only loss is data changed after the copy to the local location
When one of my users is having sever problems with his .proi, I can copy
the .proi onto my computer and work with his data to resolve the error
or conflict. The copied data is just as viable from my computer as the
original data is on his. We coordinate prior to check in to Commonspace
and when done, I delete his .proi from my computer.
Instead of copying the .proi data to a network location for nightly
backups, we have the nightly backups attach to each the engineering
computers through the network and backup the prowork folders. Full
backup Friday night, incremental backups Mon, Tue, Wed & Thurs
We require that the engineers chose Restart when they leave for the
evening, leaving the CPU powered up over night to facilitate the
backups.
Michelle McMasters
Engineering Systems Administrator
Black & Decker Hardware & Home Improvement
michelle.mcmasters@bdhhi.com
IMPORTANT NOTICE: This message is intended only for the use of the
individual or entity to which it is addressed. The message may contain
information that is privileged, confidential and exempt from disclosure
under applicable law. If you are not the intended recipient, you are
notified that any dissemination, distribution or copying of this
communication is prohibited. If you have received this communication in
error, please notify the sender immediately. Thank you.
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
