Got the solution. Needed to go a little deeper and add the message file to
the folder <loadpoint>\text\usascii and the Model Program will find it.
One other suggestion was to set the text_dir parameter in the protk.dat
file, but that is not possible for Model Programs, only for normal Pro/E
session programs.
Once again this community has proved its great value.
Bjarne Frandsen
Original question:
Hi all,
When using Model Programs, there is no way to assign where Pro/E should
look for the message files in the dialogbox.
When placing the message file in the working directory, the application
will find it, but that is not a good solution for a production
environment.
Does anyone know a central place to put message files for Model Programs
or how to point at a specific location? Have tried <loadpoint>/text
without any success.
