Thank you everyone for your quick responses. The method is quite simple,
once you have your data in the correct format.
<<you can=" import=" the=" points=" and=" create=" the=" curves=" afterwards.<br="/>
The format should be in columns so you'll need to format the excel file.
x y z
Save it as a text file and change the extension to .ibl or .pts (not
sure which one works best if there is a difference)
Start a new point that is an OFFSET COORDINATE SYSTEM POINT (it's in the
datum point flyout).
Select a c-sys and hit IMPORT.
Then choose your file.
Finally make a datum curve through points, select a spline for the type
(not single nor multiple radius), and select whole array (instead of
single point), pick the first point and it should send a curve through
all of them. >>
