A few months back I created program that inserts tables and fills them with text. I have to insert the tables as opposed to creating them, because I need to control line display over variable conditions. Anyway, the users now want to make the drawings 1 to 1 scale as opposed to scaled - drawing size is variable, 804 X 516. I have had to scale up (resize) the existing tables I'm inserting by 24.39, and also scaled up the text size. However, when I write to this table, the text will always come in at the default size of 0.625. I have set the file drawing properties but that doesn't matter. If I enter text into the tables manually, the text size comes in big, its only when I add text using toolkit where it comes in very small. I'm adding text using:
ProDwgtableTextEnter(table, col, row, lines);
Any ideas? I'm out of them!
