I'm updating a toolkit app, and need to extract the current drawing sheet's width and height. ProDrawingSheetInfoGet appears to be the correct call. However, the output doesn't seem correct. ProDrawingSheetInfo is mapped to prodrw_sheet_info, which is defined as follows: typedef struct prodrw_sheet_info { ProPlotPaperSize type; int width; int height; int units; int orientation; } Prodrw_sheet_info; How can the width and height be integers?-- Gerry Champoux Williams International Lead Engineer 2280 I. West Maple Road Information Technology Walled Lake, MI 48390 (248) 624-5200, x2816 (248) 960-2607 (fax) - http://www.williams-int.com
