Hi all,
I am seeing some strange regeneration behavior with a simple assembly I've built. The assembly has three assembled components (A, B, and C). There is an input parameter, CONTAINER, at the assembly level. The components are being added and suppressed in the assembly via thefollowing program:
IF CONTAINER == 1
ADD PARTA
INTERNAL COMPONENT ID 56
END ADD
END IF
IF CONTAINER ==2
ADD PARTB
INTERNAL COMPONENT ID 61
END ADD
END IF
IF CONTAINER ==3
ADD PARTC
INTERNAL COMPONENT ID 49
END ADD
END IF
In the assembly, the initial value of CONTAINER = 1. So, when I open the assembly, component A is present in the assembly and B and C are suppressed.Now for the strange behavior part: When I change CONTAINER to 2 and regenerate the assembly, component A regenerates completely, THEN A is suppressed, THEN B is added and regenerated. I don't understand why A is regenerating before the program suppresses it, nor do I want A to regenerate prior to being suppressed. I have checked for circular references and don't find any.
Anyone out there dealt with this before? All clues are greatly appreciated!
Tyler
