VB API. Problem with Selection.
JoeVarghese
I an using VB API. I am able to allow the user to select Component or feature by using the string identifier "membfeat". By using that I am able to make that selection. The problem is that I am not able to differenciate what selection type it is? As far as I understand, i have to use the property "SelItem" to access the feature selections and I have to use the property "SelModel" to access the components. But I could not identify the type of selection so that I can use either of these. Is there a property (or method) in "IpfcSelection" or "IpfcSelections" or somewhere else whcih I can use for identifying it? Thanks & regards Joe. ---------------------------------------------- you can find some tips at... http://tipsfromjoe.blogspot.com ---------------------------------------------- .
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
