I see in wildfire 4 the hole GUI has changed slightlyand for the better IMO.
The Question after showing the default note on my drawing for the hole how does one change the output? where is the note information coming from (the .hol file?)
For instance here is what I would like shown in my note for a 1/4-20 tapped hole.
#7 (.201 DIA.) DRILL x .60 DEEP
#1/4-20 TAP x .50 DEEP
C'SINK TO FULL THREAD DEPTH
Also where did the note editor and Ref Dim go?
Pulldown / Edit/Setup (Ref Dim?) (Note?) in W3 it's there W4 it's gone
JScott
Ok Well I found where the Note and Ref Dim is hiding.
Part Mode: Insert\Annotations\Notes \Ref Dims
The W4 Menu mapper makes no mention of this.
So now I will continue my search for custom notes for the Hole GUI.
JScott
