crane book model in swept blend
ptc-2092024
Hi friends., I am trying to design a crane hook using swept blend in pro/e wf2. I am difficulty in completing that model. the model consist of a) circular section, b) section with 7 entities (elliptical cross section with taper on both sides) and c) tip of the crane (i used a point for this) But, i am not successfully design the part. can any one help me with the crane model or tutorial to design that. regards., sekar
sekar, With a little more detail, perhaps we could be a little more helpful. Meantime, three comments: (1)Except for the point at the end, all sections need to have the same number of entities for the blend to work, so the circular section needs to be divided into seven arcs to match the seven pieces of the other section. (2) If appropriate, you might consider dividing the shape into more than one portion. Trying to force it all into one Swept Blend may create more trouble than it's worth. If you do divide things up, you can force tangency between portions using various methods. (3) Consider using Surfaces first to create your geometry, before finally using Solidify; generally, this affords much more flexibility. David
Just like David mentioned. Ensure the segments in the section match and also the direction to get a good surface. For the tip of the hook you have an option of having sharp or smooth (swept blend option). In general try to keep less number of segments in the section to have better control of the geometry.. Keep trying.. Chander
Hi Balachander and David., Thanks for your suggestions. I tried it again and able to finish it off. Thanks for the guideline give by both of you. regards., sekar.r
