I want to tranform propoint3d of curve end point by userdefined coordinate system
for this i tried the following steps
1. get x_vector, y_vector, z_vector,orgin (from ProGeomitemdata) from user defined coordinate system
2. construct a ProMatrix using these inputs (ProMatrixInit())
3. Transformed propoint3d with ProMatrix as input
But the resultant Ptopoint3d is not equal to manually measured value (Analysis-> Geometry -> point)
For example if user defined Csys is created o nthe end point of the curve , and if tranformed that point3d , resultant value should be 0 0 0 ideally ,but toolkit is giving some other result
If you got any idea , please give me a reply
