Coincidentally, the JLink example applications include a simple parameter editor. %pro_home%\jlink\jlink_appls\jlink_param. It's not anything special and it is very oldbut it does work and itcould certainly be extended to filter predefined parameters. It also would allow you to set up preset lists of values for select parameters.
