I am working with two Auxiliary Applications that appear to be in
conflict with each other with regards to the version of the pro_jpeglib
shared library. Individually both applications run without issue. But
when run in sequence, the following error appears when the second
application is run and the pro_jpeglib is loaded from within the load
point.
Wrong JPEG library version: library is
62, caller expects 61
Both applications are DLL's. I have checked the linked libraries of
both DLL's; neither has a direct dependency on pro_jpeglib.
Does anyone have experience with this problem?
Stuart
Stuart A. Harvey
🙂 stuart.a.harvey@boeing.com (eMail gets noticed)
😞 818.586.0388 (phone msgs may be recycled)
