pro-program question
snellutla
Hi Guys,
IF A < 4
IF A < 3
B = “P”
ENDIF
ELSE
B = “Q”
ENDIF
C = “XXX –YY - &A &B”
I want to achieve C based on A and B values
For ex: if A = 5 --> B = Q
And C = XXX – YY – 5 B
Where as C = “XXX –YY - &A &B” is returning XXX –YY - &A &B and which makes sense as the above line considering it as a single string value.
Could anyone assist me in achieving this in pro-program relations?
Sharath
Hi Sharath,
To concatenate a string parameter to a string, simply use + (i.e. "XXX -
YY - " + A). If your parameter A is an integer, you need to convert it
to a string and use ITOS(A) in your relations. If your parameter A is a
real number, I'm not sure of a quick way to handle that as there is no
"real to string" function that I'm aware. ITOS will handle a real
number, but the result will be rounded off.
Here's how I would write your relations:
IF A < 4
IF A < 3
B = "P"
ELSE
B = "Q"
ENDIF
ENDIF
C = "XXX - YY - " + A + " " + B
or
C = "XXX - YY - " + ITOS(A) + " " + B
Hope this helps,
Tyler
Thanks for the response,
Input parameter A is real number. Is there any wqay to add it to "C" (string).
Tyler/Sharath,
If you want to convert the real number to string, the relation would be
similar to this:
X1= FLOOR(REAL_NUMBER)
X2= REAL_NUMBER-X2
IF X2> 0 /*Checks to make sure the number wasn't already an integer
X=ITOS (X1) + "." + ITOS(X2*1000) /* NOTE: this is for a 3 place
decimal, use multiplier values accordingly
ELSE
X=ITOS(X1) + ".000"
ENDIF
Robert Tobin
Fowler Engineering
Thanks for the help.
Sharath
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
