[procad] writing a Relation
jlippeth
Good Afternoon
I need to write a relation and having trouble finding the correct
nomenclature.
Project scope:
I am creating Spirolox Retaining Rings with quilt bodies to be used to
cut out the groove and c'bore features.
Now I could create a family table, but I want to use relations.
Relation description;
Shaft diameter = SD1
Groove dia = SD5
How would I write,
IF SD1 = 1.125 then SD5 = 1.082
IF SD1 = 1.250 then SD5 = 1.202
IF SD1 = 1.375 then SD5 = 1.323
Etc...
Hopefully I am clear in my request, Thanks
Jeff Lippeth
Engineering Group
NyproMold Chicago
P. 847-855-2226
F. 847-855-2303
- <">mailto:->
www.NyproMold.com ____________________________________________________________________________________________________...
IF SD1 == 1.125 /*make sure you get the double equal sign in the IF
lines.
SD5 = 1.082
ELSE
IF SD1 == 1.250
SD5 = 1.202
ELSE
IF SD1 == 1.375
SD5 = 1.323
ELSE
SD1 = 1.375 & SD5 = 1.323 /*this is so if some value other than one
of the three is entered that it gets a default value equal to one of the
three with the correct SD5 value also.
ENDIF
ENDIF
ENDIF
Hope that helps,
Brian S. Lynn
Technical Coordinator, Product Engineering
Thanks all with some good tips, Brian had the correct syntax with double
Here is what I came up with.
IF SD1 == 1.125 /Shaft diameter
SD5 = 1.082 /Groove Dia.
SD4 = .042 /Groove width
ELSE
IF SD1 == 1.250
SD5 = 1.202
SD5 = .048
ELSE
IF SD1 == 1.375
SD5 = 1.323
Sd4 = .048
ENDIF
ENDIF
ENDIF
Thanks again, Happy Friday to All!
Jeff Lippeth
Engineering Group
NyproMold Chicago
P. 847-855-2226
F. 847-855-2303
- <">mailto:->
www.NyproMold.com
www.NyproMold.com
Sorry my email had a typo,
ECN 080808 Rev-B
SD4 = .048 was SD5 = .048
Jeff Lippeth
Engineering Group
NyproMold Chicago
P. 847-855-2226
F. 847-855-2303
- <">mailto:->
www.NyproMold.com
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
