Dear User,
I have develpoed application using weblink. I am going to develop an
application using Pro/Toolkit. The application has to read huge data
from oracle which will be then used for model. (total number of GUI are
also more).
Application should support multiple language apart from English
Can anyone suggest which of the following approach is BEST?
First approach can be
From the Pro/Toolkit documentation I am plannning to develop application
with
1. Pro/Toolkit UI..(Resource Files)
2. Synchronous Mode EXE using C language
3. Reading from oracle database using C ( Pro*C ) and using that
values in Pro/toolkit functions
Second approach can be
1. MFC based GUI using DAO
Third approach can be
1. GUI using VB.net using COM
I should go for Synchronous application or ASynchronous mode ? What are
the pros and cons of each mode?
Thanks a lot in advance.
Akash
