vendor part will not open
hspaulding
3-Visitor
I recieved a Pro/E part from an outside source and I cannot get it to open.
I get this error message "The file C:\Work\j13344.prt.1 is not a valid PART file."
Anyone got a solution or answer for me.
I am using Wildfire 3.0.
I have added the file for your experimentation
7 REPLIES 7
I opened the file with a text editor, and in the header I see this:
#UGC:2 PART 1422 780 802 1 1 15 2900 2008310 000007ac \
#- VERS 0 0 \
#- HOST \
#- LINK \
#- DBID \
#- REVS 0, \
#- RELL 0, \
#- UOBJ_ID 1164877878 1134236305 614656413 \
#- MACH _Windows \
#-END_OF_UGC_HEADER
#P_OBJECT 6
@P_object 1 0
(bunch of stuff deleted)
@last_read 27 1
1 27 -1
#END_OF_P_OBJECT
#Pro/ENGINEER TM Wildfire 4.0 (c) 2009 by Parametric Technology
Corporation All R
Looks like you've got a version problem.
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
That is what GCRI is for. It allows you to pull up WF4 files in WF3.
I've done it with WF3 in WF2, and would expect it to work the same.
Sincerely,
Brian Toussaint
CAD Administrator
These views are mine and not necessarily those of my employer.
Hoshizaki America, Inc.
618 Hwy. 74 S., Peachtree City, GA 30269
Yep. I couldn't open it in WF2, but I could in WF4. Interestingly, I
did not get the usual 'newer version' message. Didn't Pro|E used to
tell you if it was a newer file?
Doug Schaefer
LinkedIn
Thanks for the quick response, everyone.
The first thing I told the supplier was that we were on Wildfire 3 and would need a compatable file. GRRRRR!!!!
I guess he doesn't listen well!
In Reply to Herb Spaulding:
UPDATE:
As suggested by some, I tried downloading/setting up the GRANITE Cross Release Interoperability (GCRI) software from the PTC website.
What I got for my troubles was when I tried to open Pro/E I get a Pro/Exit.
Thanks PTC!
I have a call in to the PTC helpline, but I'm not holding out for much.
CBenner
(To:hspaulding)
What you are seeing in the text file makes me wonder if this isn't in fact a Unigraphics part file. UGC usually refers to Unigraphics.
<u>
</u>
Chris Benner
Autodesk ® Expert Elite
CBenner
(To:hspaulding)
Nope.... never mind. It opened right up for me with no trouble.
<u>
</u>
Chris Benner
