Controling a Sketched Datum curve in a Skeleton with a Assembly Parameter
Newbie
MorningGroup
This is what Iam trying to do:
Create a family table that shows the different position of an assembly that is controlled by a datum curve in a Skeleton.
This is what I tried:
I have a skeleton that controls the position of componenents in an assembly. I want to create a family table to show the different positions of the assembly. I created a parameter to control the position (it is an angle). I then created a relation in the assembly to control the angle of a sketched datum curve in the skeleton. When I try to edit the skeleton datum curve in assembly mode and part mode it tells me that the dimension is controled by a relation.
This is what is not working:
The problem is the model does not want to regenerate with the new values I assigned in the family table.
Thanks in advance for any help you can give me.
Stephen
