Creating labels on parts using .jpg images
Newbie
We are trying to create labels for our machines using a part, which is
just an extruded rectangle, and applying a decal or texture to it from
the Colors and Appearance dialog. Everything works fine when it is
created, but after closing the session of Pro, starting a new one and
opening the part, the image is gone. Looking back at the Colors and
Appearance dialog, the decal box is still checked, but it can't find the
image.
We have the pro_texture_library and texture_search_path set to the
loadpoint (C:\PTC\ProEWildfire), and all of the images are in the
subdirectory (...\graphic-library\textures).
Anyone have any idea why they aren't showing up? Thanks in advance.
Jeffrey Cowan
Mechanical Engineer, Machinery Operations
MiTek Industries, Inc.
Phone: (314) 851-8461
Fax: (314) 298-3439
jcowan@mii.com
This communication (including any attachments) contains information which
is confidential and may also be privileged. It is for the exclusive use
of the intended recipient(s). If you are not the intended recipient(s),
please note that any distribution, copying or use of this communication or
the information in it is strictly prohibited. If you have received this
communication in error, please notify the sender immediately and then
destroy any copies of it.
Re: Creating labels on parts using .jpg images
The way to do this is to change the default value of save_texture_with_model to YES.
