EMX component library
PedroNeves
7-Bedrock
is there any way of placing my emx components with a repeat function?
I have several componentes to assemble, and i don't want to open the interface window again.
I want to have the same option that emx have for placing water lines.
you chose the componente, and that you just have to select the curve and the plane in "LOOP MODE"
Is this possible?
thanks
Pedro Neves
6 REPLIES 6
florin
(To:PedroNeves)
Hi Pedro,
To do that just set the EMX-Option AUTO_REASSEMBLE_ALL_TYPES to YES and you can assemble new components of the same type in a loop whick you can interrupt with a Middle-Mouse-Button click.
Florin
Hi Florin
Thanks for the tip!
I'm gonna use that for sure
Regards
Pedro Neves
Hi Florin,
i have changed the value to "Yes", but the loop still doesn't work...
Any ideas for why this is happening?
Thanks again!
Pedro Neves
The loop only doesn't work on my own library componentes...
florin
(To:PedroNeves)
Hi Pedro,
This is correct, that function is not yet implemented.
Florin
tschneyer
(To:florin)
Hello Pedro,
it will be available with the new release EMX 9 M012 comming in April 2016.
Regards
Thomas
Ryan Kelley‌ please add to Expert Moldbase Extension - EMX
Kind Regards
Thomas Schneyer
B&W Software GmbH
