How do you edit/create a title block in Creo Elements/Direct Modelling Express?
ptc-4054368
2-Explorer
As per the title, my question is literally:
O
Hello Oliver,
You can load a drawing frame in Annotation. For example:
C:\Program Files\PTC\Creo Elements\Direct Modeling Express 4.0\annotation\win\format_A4.mi
But unfortunately you can not save him in the .mi format.
In the full version there is an option to save as a frame.
But if you have Drafting then you can make the changes there.
Save the changes as .mi file into a directory of your choice.
In order to use the new frame in Annotation you create in
C:\Users\YOUR_NAME\AppData\Roaming\PTC\Creo Elements Direct Modeling Express 4.0\40.0\ANNOTATION
a file "am_customize" (no extension!) like in the attached example, or use the sample file and change the paths + names.
Pay attention. The delimiters in the path name must be "/" like in Unix.
Best regards
Friedhelm
(Please write info in your Signature) Sysinfo: I use Creo Elements Direct Drafting, Modeling and Express 6-8-9 ( formerly CoCreate- SolidDesigner and Drafting or ME10 )
