Sometimes you need to add an existing something into a model your setting up. It does not need to be a perfect match to reality but at least look a little bit like it.
Or you have a drawing that has not all dimensions. And instead of measuring from a photo or drawing it might be nice to sketch directly on top of the drawing/photo in cocreate.
Is there any way to do such a thing?
Load a picture scale it etc etc as a workplane for instance or fix a picture into the 3d space in an other way?
I know you can load a picture as a background image to a viewport but, 1 the scaling is hard to do and non permanent 2 and you can't zoom in on parts. So it would be nice if there was another solution.
Thnx in advance for enlighting me ![]()
If you can get your 2D photo or drawing into a DWG or DXF format it can be loaded into the Annotation Module. Once in Annotation, simply click "Ctrl c" (Copy) on your keyboard and then draw a window box around the image/view you want to use. Then toggle back to Modeling, create a new workplane, and then click "Ctrl v" to paste the image/view on to the workplane.
Hope that helps!
~chris
Well that is a coincidence ... Just today I was going to add some covers onto an existing part .... So I took pictures.
Anyway eventhough making a dwg from a drawing is not the way to do it. I did remember that you can import pictures directly into annotation and you can size them.
Now I have not figured out how to get them to the size i need them but that is just a minor detail...
Once you got your picture in annotation you can trace it and indeed copy the lines back into a workplane as you suggested.
So I must thank you for bringing me to the right path
So making a model from a 2d picture or whatever is possible through annotation. I still would like to see that you can load a picture into a workplane and scale it there. But this will do.
