Issue with CED 20.6 Operation: Unable to Modify View in Read-Only Mode
Haydena
Dear Sirs,
I hope this message finds you well.
I am currently encountering an issue while using CED 20.6. Specifically, when attempting to insert a section view while editing a drawing, I receive the following error message: "The selected view belongs to a read-only part or assembly," which prevents me from proceeding with further edits or operations on this view.
I have attached a screenshot of the issue (please refer to the attachment) for your reference.
I have attempted the following troubleshooting steps, but the problem persists:
  1. Verified whether the part is set to read-only mode.
  2. Restarted the software and reloaded the drawing.
  3. Tried loading different parts, but the issue remains the same.
Could you please advise on how to resolve this issue? Is there a way to adjust the settings to remove the read-only status of the view?
Thank you for your time and assistance. I look forward to your guidance on this matter.
Best regards,
Lan
Hi @Haydena,
Thank you for your question.
Vivek N
Community Moderation Team.
Haydena
(To:vnamboodheri)
Dear Vivek N,
Thank you for your response and for raising awareness about my issue.
I understand that this might be a specific or uncommon problem, but I would really appreciate any insights or suggestions from the community. I am still facing the same issue and have yet to find a resolution. If there are any additional troubleshooting steps I might have missed or alternative approaches to try, I would be grateful for the guidance.
Thank you again for your time and support.
Best regards,
Haydena
lfortner
(To:Haydena)
You may read documentation at https://support.ptc.com/help/creo_elements_direct/r20.7.0.0/advanced_documentation/goodies/Readme-0022.html and/or https://support.ptc.com/help/creo_elements_direct/r20.7.0.0/advanced_documentation/goodies/Readme-0098.html
enter the command
(load "dbdialog")
and the tools box button will offer you a dialog to manage objects flags as clearing Read Only.
Assume your choices.
AndrewK
Community Manager
(To:Haydena)
Hi Haydena,
I wanted to follow up with you on your post to see if your question has been answered. If so, please mark the reply as the Accepted Solution for the benefit of other members who may have the same question.
Of course, if you have more to share on your issue, please let the Community know.
Andrew
