Dear everyone
I have some question about using Element drafting 20.1.4 as below ;
1. I create geometry whatever line rectangle circle, it show black box instead show value . What cause of this problem ?
2. When I create rectangle, it not parallel with monitor as capture screen.
(Please see capture screen in attached file for clearly understand )
If I guess, all of this problem cause from Evaluation mode ? I'm not sure.
Anyone who have experience about this problem. Kindly guide me how to solve this problem
I'm looking forward to hearing from you.
Thankyou
James
Dear James,
1. This should be the values x and y of the current position of the cursor. You can change foreground and background to see the text with:
Tab File > Settings > System...> Copilot
and then "Text Box" "Text" and "Bakground".
2. You are in the isometric mode. You can change back to normal with:
Tab View > Drafting > Setup >
and then Grid... > Reset
Dear James,
Nothing to do with evaluation mode.
