In SCCM sandbox view window, there are certain fields like member revision, CPID, revision number etc.
Is it possible to add more visible fields in that window..If yes please guide me how?
What i want to achive is, lets say there is a final tested code in sccm and across that code, i want to attach a "code compliance" (lets say PRQA report) report to it.
It is possible to added additional pre-defined fields to the sandbox view. To do this, right click on the column headings and select "Configure Columns". However, this will not accomplish what you want as you cannot create a new field to add.
There is currently no way to attach a file to a configuration managment project or member. There are some other options that may work for you:
